November 23, 2010 at 4:58 pm #107392ix studioMember
Hi
i turned on my h8000fw today after not using ita few weeks and i get
error messages
config jumpers ln102 . ln103 invalid
check u106
and a very weird and unusable h8000.
Is it worth me trying to update to 5.5 ? or can you guys let me know what these erorrs mean and if i need to just bypass trying stuff and send it for repair ?
i am in the uk.
thanks for any advice.
November 23, 2010 at 5:08 pm #121027
The check U106 message may be a clue. If you are technical, you could open the unit (power off) and wiggle any socketed parts (especially U106 – square chip in center of main board).
If you are not, or don't feel you should have to do this, you should take it to your local service centre – in the UK that would be HHB.
November 23, 2010 at 5:40 pm #121028ix studioMember
Cheers nick , i lifted off the lid and checked all the leads and just gave them a little pressure and itss now powering on fine so i guess this was the issue , its been sat in the same position for 5 years so i ama bit baffled as to what changed , i couldnt find any lose connectors so its really a subtle connection issue but its cool right now so many thanks
matt
November 23, 2010 at 5:51 pm #132182
Sorry you had a problem, but glad it's now fixed. We've had a few problems with the socket for U106 – current production has the part soldered to the board.
Also, if you're so inclined, check that all the motherboard mounting screws are present and tight – if they are loose or missing the board can flex if the unit is moved, which can distort the socket.
Hardware is much harder than software …
November 26, 2010 at 12:58 pm #132190lxsParticipant
I've had the same issues and fixed it in the same manner
