H 8000 FW
Home Forums Products Rackmount H 8000 FW
Viewing 5 reply threads
    • #105369
      ulfiyya
        Hi, I heave a GTR 4000 and Eclipse.
        Some one told me if i bay a H 8000FW i don 't need GTR an Eclipse any more.
        I can make more alogaritm and more effects just in one preste insteade of both GTR and Elipse,is that right?
        Thanks,
      • #116991
         Yes. As correctly adviced on EvHelps your Eclipse+GTR4000 combined together will be simply be less useful and powerful thn a single H8000FW.
        If you simply consider that the H8000 comes w/almost 2000 presets……and VSIG work may go ad infinitum……..
        cheers
      • #117073
        ulfiyya
           And are there Eclipse presets included or can i overwrited to H 8000?
        • #128135
           The H8000FW ahs more advanced versions of the Eclipse ones. You'll find some. You can't overwrite H8000FW presets with Eclipse ones.
          best
        • #129687
          ulfiyya
            Hi ,
            I 'm again for last question i hope!
            After evry prest in the manual is 2,2 or 4, 4 ..
            Is that mines 2 dsp or 4 ? of one processor?
            I learn that h 8000 in total 8 dsp in each proc?
            Thanks!!!
          • #129688
            The numbers you refer to, indicate the quantity of inputs and outputs of a preset.
            A preset with 22 means it has 2 inputs and outputs, a stereo preset.
            A 44 is quad input/output preset.
            Regarding dsps, the H8000 is a dual machine using 2 DSPs; each machine uses a single dsp.
            all the best
            I
