H-8000FW internal routing configuration
Home Forums Products Rackmount H-8000FW internal routing configuration
    • #105660
      Hi Italo
      I was wondering, the manual says that if you press program, enter 20 then ent, select you should be in the routing preset (firewire 8track AB). Altough i can't find number 20 anywhere.. 😉
      Is there an explination for this?
      Jorik
    • #117530
      Hi Jorik
      you have to *press & hold* PROGRAM to enter the Routings area…then choose the routing you need.
      best
    • #117533
