I’m trying to use a modified version of patch 521-MICROPITCH-SLAP, with the SLAP softkey amount at 0%. Steps to reproduce: Load H3000 on a track. Use the Plugin’s patch-selector dropdown to bank 02-Vocals->02 – 521-MICROPITCH-SLAP. Adjust SLAP softkey 3 to 0%. Save new patch called 521a-MICROPITCH. When I load that new preset back in, the plugin behaves like the SLAP value is back at the 521-MICROPITCH-SLAP default of 51%, but displays 0% in the window.
Further, if I don’t bother with custom patches and just adjust plugin settings, save my session in DP and thenr reload the session back again, the same thing occurs (SLAP display reads 0%, plugin has delay as if at 51% default). This is extremely frustrating on session with multiple instances of H3000, as I have to go back to each instance and reset my custom settings from scratch.
This is happening with both the AU and VST versions of the plugin.
Please advise.
Best,
Guitardood
