H3000 Band Delays Native In Logic Pro 10.4.4
Home Forums Products Plug-Ins H3000 Band Delays Native In Logic Pro 10.4.4
Viewing 3 reply threads
    • #163890
      Leturk07
        HI
        H3000 Band Delays Native In Logic Pro 10.4.4 can’t open , my OSX is Sierra 10.12.6
        The following Audio units message appears
        validating Audio Unit H3000 Band Delays by Eventide:
        AU Validation Tool
        Version: 1.6.1a1
        Copyright 2003-2013, Apple Inc. All Rights Reserved.
        Specify -h (-help) for command options
        VALIDATING AUDIO UNIT: ‘aumf’ – ‘BDls’ – ‘Tide’
        dyld: warning, LC_RPATH @executable_path/. in /Library/Audio/Plug-Ins/Components/ERA6_DeBreath.component/Contents/MacOS/ERA6_DeBreath being ignored in restricted program because of @executable_path
        dyld: warning, LC_RPATH @executable_path/. in /Library/Audio/Plug-Ins/Components/ERA6_DeClipper.component/Contents/MacOS/ERA6_DeClipper being ignored in restricted program because of @executable_path
        dyld: warning, LC_RPATH @executable_path/. in /Library/Audio/Plug-Ins/Components/ERA6_MouthDeClicker.component/Contents/MacOS/ERA6_MouthDeClicker being ignored in restricted program because of @executable_path
        dyld: warning, LC_RPATH @executable_path/. in /Library/Audio/Plug-Ins/Components/RegrooverPro.component/Contents/MacOS/RegrooverPro being ignored in restricted program because of @executable_path
        dyld: warning, LC_RPATH @executable_path/. in /Library/Audio/Plug-Ins/Components/Rhythmiq.component/Contents/MacOS/Rhythmiq being ignored in restricted program because of @executable_path
        2022-05-30 19:22:56.734 auvaltool[6353:23179059] There was an error parsing the Info.plist for the bundle at URL <0x7fec32908800>: NSCocoaErrorDomain – 3840
        2022-05-30 19:22:56.735 auvaltool[6353:23179059] There was an error parsing the Info.plist for the bundle at URL <0x7fec32908ad0>: NSCocoaErrorDomain – 3840
        2022-05-30 19:22:56.735 auvaltool[6353:23179059] There was an error parsing the Info.plist for the bundle at URL <0x7fec32909080>: NSCocoaErrorDomain – 3840
        2022-05-30 19:22:56.736 auvaltool[6353:23179059] There was an error parsing the Info.plist for the bundle at URL <0x7fec32909420>: NSCocoaErrorDomain – 3840
        2022-05-30 19:22:57.002 auvaltool[6353:23179059] There was an error parsing the Info.plist for the bundle at URL <0x7fec32a35050>: NSCocoaErrorDomain – 3840
        Manufacturer String: Eventide
        AudioUnit Name: H3000 Band Delays
        Component Version: 3.7.11 (0x3070B)
        * * PASS
        TESTING OPEN TIMES:
        COLD:
        FATAL ERROR: OpenAComponent: result: -1,0xFFFFFFFF
        validation result: n’a pas pu s’ouvrir
      • #163891
        Leturk07
          H3000 Band Delays Native is well open in Ableton Live 10 suite , but i don’t use it
        • #163892
          Leturk07
            Thanks for answer …. but
            hi
            It was done at the first step of the install , the HE 3000 component is  in the components file and visable in Logic pro but can’t  open it
            the same component  is well opened by Ableton Live 10
            Le 30 mai 2022 à 18:49, Eventide Audio <noreply@eventide.com> a écrit :
            Your H3000 Band Delays 30-day demo has been successfully deposited into the iLok account leturk07
            You can download the installers here: https://www.eventideaudio.com/downloads?product=H3000+Band+Delays
            If you would like to purchase the plugin, you can do so at our webstore by following this link: https://eventide-store.myshopify.com/cart/30337491468345:1?channel=buy_button
          • #163906
              Sorry for the issue you’re having. Please see below and let me know what happens.
              Plug-in isn’t working in a DAW on Mac:
              Confirm you have the latest version of your plug-in installed: https://www.eventideaudio.com/products/plugins
              Confirm that you have the latest version of iLok License Manager installed.If you already have iLok License Manager installed, open iLok License Manager and select iLok License Manager → Check For Application Updates in the toolbar.
              If you do not have iLok License Manager installed, download the installer at http://www.ilok.com and install.
              Make sure the plug-in license is activated to your machine or iLok dongle in the iLok License Manager.
              If steps 1-3 don’t solve your issue, close your DAW and uninstall the plugins.
              Newer plug-ins have an uninstaller is located at /Applications/Eventide/Uninstallers.
              For older plug-ins without an uninstaller, delete the following files:
              AAX: Mac HD/Library/Application Support/Avid/Audio/Plug-ins/Eventide/<plugin name>.aaxplugin
              VST: Mac HD/Library/Audio/Plug-ins/VST/Eventide/<plugin name>.vst
              AU: Mac HD/Library/Audio/Plug-ins/Components/<plugin name>.component
              Presets and Docs: ~/Music/Eventide/<Plugin Name>/ (whole folder)
              Open your DAW and rescan your plug-ins, and then shut your DAW again.
              Deactivate and reactivate the plug-in license in iLok License Manager.
              Reinstall your plug-in.
              Reopen your DAW and rescan your plug-ins.
              AudioUnit only: If still not showing, some macOSes occasionally require a restart for Audio plugins to correctly scan.
              Other additional things a user should check for based on their DAW:
              Logic:
              Launch Logic Pro X
              Go to Preferences->Plug-in Manager, select the desired plug-in(s) and then click “Reset and Rescan Selection”
              If the plug-in(s) fails validation, then copy the output of the validation window, and send it to us.
              If the plugin passes validation but still does not show in the Insert menus, try the following steps:Close Logic Pro X
              Make sure Finder is the active application
              While holding the Option key, click on the Go menu at the top of your screen and select Library
              Delete the following files from your User Library, if they are present:
              ~/Library/Caches/com.apple.audiounits.cache
              ~/Library/Caches/AudioUnitCache/
              ~/Library/Preferences/com.apple.audio.InfoHelper.plist
              ~/Library/Preferences/com.apple.audio.SandboxHelper.plist
              Then, open a Terminal window (located at Applications/Utilities/Terminal), and enter the following commands (type each command and press “Enter” afterwards):killall -9 cfprefsd
              killall -9 AudioComponentRegistrar
              Restart your computer
              Restart Logic Pro X
