H3000 DELAYS vs H3000 FACTORY …?
Home Forums Products Plug-Ins H3000 DELAYS vs H3000 FACTORY …?
Viewing 10 reply threads
    • #167864
      Kramer
        are all the functions in your H3000 DELAYS plugins also included in the H3000 FACTORY plugin?
      • #167870
          No, they are different plug-ins that are used for different purposes. H3000 Factory is a re-creation of the Patch Factory, Mod Factory 1, and Mod Factory 2 algorithms from the H3000. H3000 Band Delays is a recreation of the Band Delays algorithm. The easiest way to see the difference would be trying a free trial of either plug-in.
        • #173992
          raal007
            Please consider making the Magic Air patch, as found on the H3000 SE. I’ve demoed the plugin and do love it, but if it had Magic Air, i might even consider selling the hardware! BTW i own Split EQ. Talk about a lifesaver, thank you for the great products!
            Rafael
          • #174157
            medway
              Please consider making the Magic Air patch, as found on the H3000 SE. I’ve demoed the plugin and do love it, but if it had Magic Air, i might even consider selling the hardware! BTW i own Split EQ. Talk about a lifesaver, thank you for the great products! Rafael
              You can make it yourself. I did on mine.
            • #174378
              moreigloos
                What is the recipe?
              • #174379
                medway
                  What is the recipe?
                  I’ll post the preset. Original uses Multishift algo so might not be 100% but from what I remember it’s close. Will check against the hardware.
                  • #174708
                    ashmanzz
                      What is the recipe?
                      please post this preset been looking everywhere ! Thank you 🙂
                  • #174711
                    medway
                      What is the recipe?
                      Hi you can try this one. I made it a long time ago and not sure how it compares to the hardware. When I find some time soon I will check it but see what you think. It’s probably not exact as it uses a different algo but should be similar.
                      • #189130
                        dOllOp
                          Thx for posting your Magic-Air patch. Much appreciated!  🙂
                      • #174817
                        ashmanzz
                          Thank you!!
                        • #181869
                          snavid
                            Thanks for sharing ! I will try it out in the new updated MKII plugin..
                          • #181889
                            ashmanzz
                              Can confirm it sounds great and have used it a lot in my mixes. 💪
                            • #182541
                              medway
                                Glad it was useful!
