April 9, 2015 at 10:34 am #112481
aero
ParticipantHello,
I just tried installing the H3000 demo on my system but it fails validation during start up.
Resetting through AU manager has no effect.
My system:
Logic 9.1.8
Mavericks 10.9.5
Mac mini 2.3 Ghz Quad Core i7
Thanks for any help
April 9, 2015 at 4:54 pm #127698
Hi Aero,
There was a problem with the 32 bit au version number. This fixes it:
Sorry,
Dan
April 9, 2015 at 5:04 pm #138783
aero
ParticipantThank you Dan,
however the issue was with the 64bit version.
I'll try your fix anyway.
Best
April 9, 2015 at 8:02 pm #138788
I believe AU Manager will test both the 32 bit and 64 bit binary, though I'm not sure. Either way, I'm certain the 2.5.1 installer will resolve this for you.
April 10, 2015 at 6:07 am #138797
aero
ParticipantThan you Dan,
it worked perfectly
all the best
November 5, 2015 at 4:10 am #141449
KingChuck
MemberI downloaded to v2.5.1 hoping it would fix my issue, but I’m still having trouble loading H3000 plugins. They aren’t coming up in my insert lists under all my other ones. Wondering what to do. I’m in the middle of a huge project and am scared to death to update logic or even my operating system until I’m done. haha Don’t want issues. I’m running Osx 10.8.5 and Logic 9 v9.1.7 As soon as I’m done with this project I’m getting Logic X, but was hoping to get this working on 9.
November 5, 2015 at 3:32 pm #141452KingChuck wrote:
I downloaded to v2.5.1 hoping it would fix my issue, but I'm still having trouble loading H3000 plugins. They aren't coming up in my insert lists under all my other ones. Wondering what to do. I'm in the middle of a huge project and am scared to death to update logic or even my operating system until I'm done. haha Don't want issues. I'm running Osx 10.8.5 and Logic 9 v9.1.7 As soon as I'm done with this project I'm getting Logic X, but was hoping to get this working on 9.
Hi KingChuck-
Did you mean to say v2.5.10? That is the latest release of H3000 Factory available (https://www.eventideaudio.com/products/plugins/pitch-delay-modulation-filtering/h3000-factory). Or, are you also trying to load H3000 Band Delays (part of Anthology X).
When you say they aren't showing up in your inserts list, can you confirm that they've passed validation? Is there an "Eventide" subfolder under the "Audio Units" folder in the inserts list? You can check that the plug-ins have passed validation by going to Preferences->Audio->Plug-in Manager and checking that list. I would try rescanning your plug-ins to see if that solves the issue. I understand why you don't want to upgrade at the moment, but the plug-ins should load in Logic 9 without issue.
Best,
Tom
