H3000 Factory AU – LATENCY ISSUE on Logic 9.1.8 64bit when recalling project.
Home Forums Products Plug-Ins H3000 Factory AU – LATENCY ISSUE on Logic 9.1.8 64bit when recalling project.
    • #109312
      Petrosso
      Hi guys.
      I've got an issue with H3000 native plugin (AU) under Logic 9.1.8 64bit. After saving the project, closing and re-opening Logic, all tracks in the project that include H3000 instance are out of sync and have great deal of latency. The problem dissapears when: a) I turn of H3000 on a specific track b) reload the preset inside the plugin c) reload the plugin itself.
      It looks like the plugin reports latency falsely to the driver, and then PLC kicks in with wrong adjustments.
      Please review it. It's very annoying.
      Cheers.
    • #124034
      ameyrairikar
      Hi Petrosso
      Does it happen when you try to open it with a specific preset ? IF yes , is that a included preset ?
      Thanks
      Amey
    • #124035
      Petrosso
      It happens with "Stereo Chorus Clean" preset, wich is a factory preset. Just tested with couple of other factory presets and everything seems to work fine when I'm using  them.
