H3000 Factory on external drive HighSierra
Home Forums Products Plug-Ins H3000 Factory on external drive HighSierra
Viewing 3 reply threads
    • #114519
      _olsen
        the H3000 Facrory Plugin isn’t recognized by logic x since
        updating to High Sierra. It’s simply gone.
        I tried a reinstall, but I got no luck.
        I installed my audio library via
        symlink ln -s to an external harddrive.
        Any hints ?
      • #148001
        tlongabaugh
          Hi-
          When reinstalling, did you download the latest? (https://www.eventideaudio.com/support/product/52/installers)
          Does it show up in the Logic X plug-in manager?
          -Tom
        • #148018
          tlongabaugh
            Hi-
            I wouldn't think a reinstall of Logic X would be necessary.
            First, to get the obvious out of the way: I'm guessing you have other plug-ins on the external HD, that ARE showing up in Logic, right?
            Second, do you own any other Eventide plug-ins? Does this issue occur with them as well, if so?
            Can you try unlinking and re-linking the audio library to the external HD?
            -Tom
          • #148030
            _olsen
              Ok, I unlinked the audio library and installed the plugin to my internal drive,
              after changing the ownership to root:admin the plugin was found by logic.
              My external drive has a ownership “username”:staff. Maybe it’s an security problem ?
              • #148032
                tlongabaugh
                  My external drive has a ownership "username":staff. Maybe it's an security problem ?
                  I would guess it is a permissions issue, possibly related to sandboxing (security protocol on macOS). It is possible that Logic X will refuse to load plugins that are not in specific locations (e.g. the default AU location on macOS), or which do not have appropriate permissions such as "username":staff. Changing the ownership of the drive could fix this, but be careful (though it seems you have some knowledge of permissions). It's also possible that the drive you have is not in APFS format, and it needs to be (this is purely speculation on my end).
                  -Tom
                • #148275
                  radioman521
                    I would guess it is a permissions issue, possibly related to sandboxing (security protocol on macOS). It is possible that Logic X will refuse to load plugins that are not in specific locations (e.g. the default AU location on macOS), or which do not have appropriate permissions such as “username”:staff. Changing the ownership of the drive could fix this, but be careful (though it seems you have some knowledge of permissions). It’s also possible that the drive you have is not in APFS format, and it needs to be (this is purely speculation on my end).
                    -Tom
                    Changing ownership of the drive or changing permissions won’t help – I’ve yet to see a daw program find plugins that aren’t in the default locations in the OSX system drive. For samplers it’s different – you can put the content anywheres and all you have to do is to point the sampler to the right content path. For instance all my samples are on a separate drive from my system drive.
