Home › Forums › Products › Plug-Ins › H3000 Factory presets do not recall correctly after Anthology update
October 21, 2015 at 2:42 pm #112958
offaxis
Participantmy H3000 presets are not recalling correctly since updating to Anthology X
[these are the presets stored in Protools’ built-in preset manager, as opposed to the onboard plugin library]
Protools HDX1 96k v11.3.2 [Mac OS X.8.5]
October 21, 2015 at 3:29 pm #141206
Hi offaxis-
Sorry to hear about the trouble with H3000 Factory presets not recalling correctly. A few questions:
-It sounds like you are using the .tfx presets that are in the Pro Tools built in manager, is that correct?
-When you say they aren't recalling correctly, do you mean that the settings are different in between session loads, or simply when moving from the TDM version of the plug-in to the Native version?
-Did you have a previous native version of H3000 Factory where they recalled correctly?
Thanks,
Tom
October 21, 2015 at 3:40 pm #141207
offaxis
ParticipantHi Tom — answers below
YES
-When you say they aren’t recalling correctly, do you mean that the settings are different in between session loads, or simply when moving from the TDM version of the plug-in to the Native version?
I am in PT11.3.2 HDX [non TDM] — when I load a .tfx preset [created prior to the Anth X updates] from the menu at the top of the plugin window it does not load correctly. It gets it pretty close 🙂 — from my limited testing it appears to be parameters assigned to the Softkeys 1,2,3,4 that do not recall as they were saved.
I was using the most recent [pre-Anthology X] AAX version of H3000 Factory
best, Chris
October 21, 2015 at 11:36 pm #141216
Hi offaxis,
I'll look into this. Can you post one of the .tfx presets that is causing you a problem?
Thanks,
Dan
October 22, 2015 at 4:07 pm #141225
Hi offaxis-
-Do you know what specific version of H3000 Factory you were using before you upgraded? I can't reproduce on the past several versions.
-Did the preset have the softkey values set to 100, or to 9?
Thanks,
Tom
October 23, 2015 at 1:34 pm #141244
offaxis
Participant-Do you know what specific version of H3000 Factory you were using before you upgraded? I can’t reproduce on the past several versions.
I don’t know the version of the H3000 I had before.
9
