H3000 factory won’t validate in Logic 9
Home Forums Products Plug-Ins H3000 factory won’t validate in Logic 9
Viewing 5 reply threads
    • #115332
      David Goffin
      Hi, just bought the H3000 factory plugin, registered, activated with ilok on my (old) mac running OS X 10.6.8 and it won’t validate in Logic 9 (9.1.8 32 bits) – I know I need to upgrade… but I thought it should still work, shouldn’t it?
      Any ideas?
    • #151965
      David Goffin
      This is the message I get when I try to run it through the AU manager:
      validating Audio Unit H3000 Factory by Eventide:
               AU Validation Tool
               Version: 1.6.1a1
                Copyright 2003-2007, Apple, Inc. All Rights Reserved.
               Specify -h (-help) for command options
      VALIDATING AUDIO UNIT: ‘aumf’ – ‘Fact’ – ‘TIDE’
      Manufacturer String: Eventide
      AudioUnit name: H3000 Factory
      Component Version: 3.3.4 (0x30304)
      * * PASS
      TESTING OPEN TIMES:
      COLD:
      2019-05-27 11:15:20.633 auvaltool[281:a07] Error loading /Library/Audio/Plug-Ins/Components/H3000 Factory.component/Contents/MacOS/H3000 Factory:  dlopen(/Library/Audio/Plug-Ins/Components/H3000 Factory.component/Contents/MacOS/H3000 Factory, 262): Library not loaded: /usr/lib/libc++.1.dylib
        Referenced from: /Library/Audio/Plug-Ins/Components/H3000 Factory.component/Contents/MacOS/H3000 Factory
        Reason: image not found
      FATAL ERROR: OpenAComponent: result: -50,0xFFFFFFCE
      validation result: couldn’t be opened
      updating properties of AU H3000 Factory by Eventide…FAILED!
      FAILED!
    • #151975
      tlongabaugh
      Unfortunately we don't support OSX 10.6.8, so there's not much I can offer in terms of help. You could try uninstalling/reinstalling and then restarting your machine, but I'm not sure that will help.
      -Tom
    • #151984
      David Goffin
      Tried that, doesn’t work. Can I get a refund?
    • #151988
      tlongabaugh
      Email support@eventide.com and we'll sort it out for you.
    • #152056
      jothenis
      Hi. Similar situation to David’s above. Other forum pages suggest the 2.5.1 installer might work. Would it be possible to request a legacy installer in this case? I’m not currently interested in getting a refund.
      Also unable to use Precision Time Align, though Blackhole, H910, and UltraChannel are running perfectly.
      Many thanks!
      Jon
      • #152065
        tlongabaugh
        jothenis wrote:
        Hi. Similar situation to David's above. Other forum pages suggest the 2.5.1 installer might work. Would it be possible to request a legacy installer in this case? I'm not currently interested in getting a refund.
        Many thanks!
        Jon
        Sure, email support@eventide.com and we can get you a legacy installer to try.
