H3000 file locations?
Home Forums Products Plug-Ins H3000 file locations?
Viewing 3 reply threads
    • #113130
      tfelts
      I have it installed and authorized, but it is not showing up as a vst in reaper.  Where does the installer put the file(s)?  I would like to add the file path to the prefs in Reaper so that it scans the dir.
      Thanks
    • #141977
      gkellum
      You mean on Windows I'm guessing.  I believe it puts it under Program Files/Common Files/VST, but if you relaunch the installer, it will show you where it's installing to.
      • #142067
        TLTD
        gkellum wrote:
        You mean on Windows I’m guessing.  I believe it puts it under Program Files/Common Files/VST, but if you relaunch the installer, it will show you where it’s installing to.
        Had to do this so Sonar X3 would find Anthology X vst plugins also, thanks. I don’t know why the installers show one location (program files/steinberg/vst2), and they end up there. Wasted some time I could’ve been using the plugins today.
      • #142068
        tlongabaugh
        TLTD wrote:
        Had to do this so Sonar X3 would find Anthology X vst plugins also, thanks. I don't know why the installers show one location (program files/steinberg/vst2), and they end up there. Wasted some time I could've been using the plugins today.
        The installer should install VSTs into C:Program Files (x86)Common FilesSteinbergVST2Eventide for 32-bit and C:Program Files (x86)Common FilesSteinbergVST2Eventide for 64-bit. Does this installer not show this for the default location?
    • #141980
      tfelts
      Thanks.  I found it.  Showing up now.  I copied the preset folder into the same location and they are showing up as well.
      Thanks
    • #142175
      TLTD
      No, the installer did not show that location. It put everything there, but clearly went into the same location as my Soundtoys plugins did (program files x86/Steinberg) and was supposed to create the Eventide subdirectory there, but never did. I did not change anything, mind you. That was what the installer defaulted to.
      • #142186
        tlongabaugh
        Sorry, I'm not sure I totally follow. What is the file location that the installer defaults to showing when you run it? And if you leave it as default, it installs into C:Program Files (x86)Steinberg? What version of Windows are you running? Are you using the latest AX installer (1.0.6)?
