H3000 mkII In/Out not bypassing?
Home Forums Products Plug-Ins H3000 mkII In/Out not bypassing?
    • #181855
      soundsubs
        Just bought the H3000 mkII and putting it through its paces against the H3000 hardware.
        I’m noting that the In/Out doesn’t BYPASS as expected. It doesn’t change the signal at all, in fact.
        Anyone else?
        PC, Window10, VST3, Cakewalk (latest)
        —shane
      • #181880
        mibolux
          The audio metering can be set to view either input or output on the stereo meter stack. To view the input levels, click on the Levels button to light the LED. When the button’s LED is off, the meters are displaying stereo output levels.
        • #181892
          soundsubs
            My mistake!
            Is there a BYPASS button at all?
            • #181928
                There is no bypass control in the plug-in UI. You can either turn the mix down to zero, or bypass the plug-in using the DAW plug-in bypass.
