H3000 Native sidechain question
Home Forums Products Plug-Ins H3000 Native sidechain question
    • #111926
      razo
      How can I set up the H3000 factory sidechain as an Audio Unit using Ableton DAW? The picture in the user manual is different than the actual pluginwindow wrt sidechain selection / the sidechain is not visible in the top menu of the plugin window…
    • #126748
      ahumblet
      Hi Razo,
      In Ableton, let's say you have H3000 Factory on audio track 4 and you want audio track 3 to be the sidechain signal.
      1. select View > In/Out so you can view the IO section of each track
      2. In the "Audio To" section of track 3 (sidechain track) select "4-audio" in the top dropdown menu, and "sidechain-H3000" in the bottom dropdown menu.
      That should work.
      -Adrienne
