April 8, 2015 at 8:37 am #112477
geronimo
ParticipantSince the updatein 2.5.0 version, loading a patch for the H 3000 lasts approximately 20 to 30 seconds; Is this normal ?
April 8, 2015 at 12:30 pm #127691
HI geronimo,
It's not, what DAW are you using?
Dan
April 8, 2015 at 1:16 pm #138752
geronimo
ParticipantSorry for the lack of detai
: I use Digital Performer 8.07 (64 bits version) under LION 10.7.5 _
April 8, 2015 at 1:18 pm #138753
geronimo
ParticipantSorry for the lack of detail
April 8, 2015 at 1:20 pm #138754
Also, which OS, and which plug-in format (AU/VST/AAX)?
Thanks,
Dan
April 8, 2015 at 1:21 pm #138755
Ah, thanks.
We don't test against DP, but I just reached out to MOTU to try to get a license and I'll take a look at it.
Thanks,
Dan
April 8, 2015 at 1:24 pm #138756
geronimo
ParticipantIn advance, many thanks _
April 8, 2015 at 6:09 pm #138761
Hi Geronimo,
I'm not able to reproduce over here. Can you give me a bit more information?
What type of computer are you running on? Any details will be helpful.
Thanks,
Dan
April 8, 2015 at 6:26 pm #138763
geronimo
ParticipantI'm with a MacPro Rev 1.1 under LION 10.7.5 and 12 GO memory Ram . My HD System is a SSD .
Before, I was with version 2.1.1 of the H3000 and patches are loaded faster .
I have a clone of my HD System with the anteriot H 3000 version: I can testing for this .
April 8, 2015 at 7:07 pm #138768
geronimo
ParticipantIhave a MacPro 2 X 2,66 Ghz with 15 Go Memory RAM under LION 10.7.5. _
I tested with H 3000 version 2.1.1 from another HD System (a clone) and patches charge immediately.
Back on the HD System which is the recent 2.5 version H 3000 release, patches always last 20 to 30 seconds to load and freeze Digital Performer during the loading ! -
April 12, 2015 at 9:03 am #138826
geronimo
ParticipantAny news …?
April 15, 2015 at 11:58 pm #138863
Hi Geronimo,
I'm not sure I was able to reproduce this specifically, but I think I was able to reproduce something similar and just made a new build now that should alleviate the problem. We're going to test it here for a day or so and post it. Unless there's a bug, it'll be 2.5.2 when it goes up.
Dan
April 16, 2015 at 8:14 am #138867
geronimo
ParticipantMany thanks for the following; I wait _
April 20, 2015 at 3:41 am #138898
kallenem
ParticipantI'm having similar problems with Mac OS X, DP 8.07, H3000 2.5.1 AU. I just wrote a separate post describing the problem in detail. Looking forward to seeing if 2.5.2 fixes it. Thanks,
Kalle Nemvalts
April 21, 2015 at 1:31 pm #138904
radioman521
ParticipantFound out about this through a thread over in motunation and thought I'd respond here as well. On the system I have (mid 2011 27 inch iMac running OSX 10.9.5 with 32 gig ram) patch change is instantaneous in Digital Performer 8.07 with the au plugin format. Also instantaneous patch change in ProTools 11.3.1 aax plugin format on the same computer.
Jack
April 21, 2015 at 2:48 pm #138905
geronimo
ParticipantInteresting; would it be a system issue, since I am under LION 10.7.5 ?
April 21, 2015 at 6:34 pm #138907
radioman521
Participantgeronimo:
That could well be but that won't be known until others post here with their exact operating system variant. After all Lion is an old out-of-date operating system no longer supported by Apple.
April 22, 2015 at 12:51 am #138912
kallenem
ParticipantThanks, everyone, for the info. On my 7-year-old MacPro, OS X 10.7.5 is the latest OS I can run. At some point I will be forced to get a current-generation computer, but other than a few compatibility issues, my old computer is adequate for my audio projects.
For now, I will just stick with the VST version of the plugin.
Kalle
April 22, 2015 at 3:52 pm #127744
guitardood1
MemberAdd me to the list of folks experiencing this trouble. Using the H3000 2.5.1 AU with Digital Performer 8.07 on a Macbook Pro with OS X 10.10.3. Haven't tried the VST.
Patches take better part of a minute to load and interface seems a bit sluggish adjust just the Mix% parameter while a project is playing. Other plugs working just fine. Audio out of the H3000 otherwise works and sounds great.
Best,
Chuck
April 30, 2015 at 9:33 pm #138983
Hi Guys,
I believe I've been able to repro this in DP8. It's not taking 20-30 seconds, but it is taking 5-6 seconds, which it shouldn't be. It's a bit of a sticky one, so it might take me some time, but I'm looking into it. In the meantime, it does appear that VST is working fine, so please use this. Sorry for the issue, I don't know what could be causing it yet.
Dan
April 30, 2015 at 9:52 pm #138984
guitardood1
MemberThanks Dan!! And you are correct, the VST works without this issue, as a temporary workaround.
April 30, 2015 at 10:32 pm #138985
geronimo
ParticipantDGillespie:
Hi _
Many thanks for the following: would you rather give me access to the link from the previous version 2.1 ?
I can't find it on the Support Section .
May 1, 2015 at 2:34 am #138986
radioman521
ParticipantDan:
I'm curious as to what kind of Mac you're doing your development/debug on because on my system (mid 2011 iMac in OSX 10.9.5 with 32 gig ram) with DP 8.07 I'm getting almost instantaneous patch change. My system is optimized to the hilt because I also run ProTools 11.3.1 and that's as picky as they come daw-wise. I don't doubt that it's happening – could it be due to project/session size? So far I've only been running small (less than 10 tracks) DP projects/sessions.
May 4, 2015 at 5:08 pm #139003
Hi Geronimo,
Here's the older installer.
https://s3.amazonaws.com/com.eventide.plugininstallers/h3000factory/H3000Factory211osx.dmg
However, you should just be able to use the VST of the 2.5.1 release.
Dan
May 4, 2015 at 5:09 pm #139004
Radioman,
Are you using the VST or AU? This seems to be happening with the AU in DP8 only.
I don't know why yet.
Dan
May 4, 2015 at 5:40 pm #139007
geronimo
Hi Geronimo,
Many thanks: it's work fine _
May 4, 2015 at 8:09 pm #139008
radioman521
Radioman,
Dan
Forgot to mention it but I'm using the au version which like I said has been okay.
July 28, 2015 at 9:29 pm #139938
geronimo
ParticipantHello Dan _
I’m now under Yosemite 10.10.4. and with the latest H 3000 2.51 version , it’s works fine with D.P. 9. _
It was definitely a problem with LION 10.7. system ?
August 26, 2015 at 7:34 pm #140300
geronimo-
Glad to hear you got it working properly.
Best,
Tom
