H3000 stutter
Home Forums Products Rackmount H3000 stutter
Viewing 6 reply threads
    • #116467
      Is there any way to recreate the H3000 stutter algorithm in any of the newer plugins or devices?
      I would prefer an exact copy with processing delays etc. ?
      Thank you,
      Mikael
    • #157755
      John Baylies
      The H9000 has most of the H3000 algorithms on it. Check the H9000 Algorithm Manual to see if the stutter algorithm that you're thinking of was ported to the H9000: https://downloads.eventide.com/audio/manuals/h9000/H9000AlgorithmsManual.pdf
    • #178638
      Vincefromsin
      It seems there’s no other STUTTER algorithm in Eventide’s hardware apart H3000x… πŸ€·πŸΌβ€β™‚οΈ So sad.
    • #178783
      Puppeteer
      If someone could post a copy of the VSIG for this algorithm, I could have a go at reproducing it.Β  The audio signal flow isn’t too difficult, it’s mainly the UI elements where the challenge is, and I’d need to know the logic to rebuild this.
    • #179926
      Puppeteer
      The Max Stutter, arguably the most popular from the H3000 is available in the H9000 in algorithm 8010
    • #183128
      Vincefromsin
      I’m a future DSP 7000 user (hopefully!) and wonder if STUTTER can be program with the built-in patch editor? Or will it need to be a sampler (DSP 7500)?
      πŸ‘ΎπŸ’œπŸ˜ˆ
    • #183129
      Vincefromsin
      Uhhmm ok DSP 7500 > PROG 8010 ‘Max’ Stutter.
