h7600 how to load a program on vsigfile
Home Forums Products Rackmount h7600 how to load a program on vsigfile
Viewing 3 reply threads
    • #105745
      saugy
         Hi
         I just bought a h7600 and was wondering how to do some "reverse engineerinig" in order to learn how the existing programs are assembled. For example, I saved the ring modulator 5111 from the h7600 to the memory card, and then triedd to load it from Vsigfile from my computer, but as it is a *.bin file I couldnt do that. Is there a way to do it?
         Sorry for my stupid question  but I really dont see how to do that 😉
         Thanks
        D.
      • #117697
         Hi D
        Vsigfile only works with the H7600 directly connected to the PC, via a serial COM port & serial cable or an USB to serial adapter (for those PCs having no com ports). You can't edit files on a card. Please refer to Vsigfile user manual for details on this.
        all the best
        I
      • #117706
        J20056
          It also works via MIDI which I use all the time, as long as your PC has a MIDI interface. Italo mentioned that Serial would be faster and more relaible, but I find that downloading even a complex preset takes no time at all.
        • #128852
          saugy
            Thanks for the answer, I will try it and come back when I have some news
