H7600 Midi In Port, (7-pin)
Home › Forums › Products › Rackmount › H7600 Midi In Port, (7-pin)
Viewing 3 reply threads
    • #107345
      DanielH
        Hi
        from manual:
        "– The connector is 7 pin.  It can also send MIDI messages from this
        connector to a suitably equipped system. –"
        I would like to know the pinouts of the 7-pin Midi In socket and does it provide a dc-power like the Eclipse?
        Cheers, Daniel
      • #120905
          Oops – this will be from an old text. Sorry.
          The 7600 does have a 7 pin MIDI in, but there is no way to get to the extra pins – there's not room on the motherboard for the extra sockets.
        • #120906
          DanielH
            OK, I understand no power. Is there still Midi going in/out on the 7-pin?
            Would like to build a 2-way cable for my controller.
          • #132101
              There is MIDI in and out on the 7 pin.
              The 2 power lines are connected to  2 testpoints on the motherboard, to the right of the 2 relays to the left of the MIDI sockets – labeled MIDIPWR and MIDIGND. Note that  their use is not supported, so I can't tell you anything more than this.
