H7600 mono in stereo out for guitar.
Home Forums Products Rackmount H7600 mono in stereo out for guitar.
Viewing 3 reply threads
    • #107112
      eggwheat
      I want to plug my guitar mono pedal effects into one input of the H7600 and get stereo effects.
      However when I do this I either get effects just on one channel and nothing on the other or one side performing normally and the other totally wet, so if I back off the wet/dry mix to totally dry I only have one output.
      How do you set it up so I can get an equal stereo out from a mono input? I dont remember having this issue with my H3000.
      Thanks, Phil.
    • #120472
      Some of the effects are mono in mono out, some are mono in stereo out and some are stereo in stereo out. There is not an input selector.
      You best bet is to use a suitable Y lead to connect to the 7600.
    • #120475
      eggwheat
      Thank you. For such a complex do-it-all machine I'm quite amazed there is no simple global select to have a mono input on either input. Especially as the H series is famous for it's use with guitarists. I may be going mad but I thought even the H3000 has this.
    • #131704
      The H8000 has all this – the 7600 is deliberately much simplified.
