H7600 rotary dial behavior question
Home Forums Products Rackmount H7600 rotary dial behavior question
Viewing 0 reply threads
    • #115264
      Hi all!
      I’m new here — I bought a used H7600 a few months ago and I’m finally finding time to dig into it.
      Sorry if this is already answered elsewhere, but I can’t find it.
      I have one quick question — The black rotary dial on the front panel seems to pause as I rotate it, once per revolution. Is that normal behavior?
      For example, if I’ve selected a frequency cutoff and I”m rotating the the knob at a constant rate, once per turn the value will stop changing momentarily, and then continue changing again as I continue rotating it. I would expect the value to change continuously as I keep rotating the dial.
      Is there a setting that overrides this? Is my rotary encoder broken? It seems a little unusual that it acts this way.
      Thanks,
      Russ
