H7600 set-up for -10 Guitar FX Loop usage.
Home Forums Products Rackmount H7600 set-up for -10 Guitar FX Loop usage.
Viewing 3 reply threads
    • #105481
      Armando
        I'm considering the H7600 as an FX processor for my Mesa Boogie Road King's series FX loop. It's an unbalanced fx loop. On the Lexicon processors, you can set the Input and Output operating levels to -10 or +4. How do you accomplish this with the Eventide? Thanks!
      • #117202
         Hi Armando
        we use XLRs for balanced and unbalanced +4 line levels. You'll need cables wired as balanced on the XLRs side to unbalanced to the 1/4" side.
         You may want to check out Technotes here, for further detailed info:
        http://www.eventide.com/AudioDivision/Support/Knowledgebase.aspx
        all the best
      • #117203
        Armando
          Yes, I realize this but is there a way to set the machine for -10 operation or is it fixed at +4 only?
        • #128292
           Eventides do not need -10/+4dB switching. The difference is handled by the type of connector used. If you connect to the XLR inputs you'll have a +4dB properly matched impedance…connecting to the 1/4" inputs will match -10dB levels.
          It's just a matter of cables/connectors and wiring.
          best
