H7600 V5.22 release now available !!
Home Forums Products Rackmount H7600 V5.22 release now available !!
    • #105677
        V5.22 sotware for the H7600 is now available on the H7600 support section of eventide.com
        Release Notes
        This is a maintenance release with a number of small improvements and bug fixes, the main ones of which are listed below.
        Improvements:
        ? both actual MIDI channel and base+offset are shown on controller screens.
        Bugs Fixed:
        o nextprog and prevprog both give next program
        o channel and other info are not visible from EXTRIG,EXTCONTR modules
        o MIDI base channel change does not cause change in actual channel. NOTE: after this upgrade, leave MIDI channel set at the default value to keep the same actual channel ssignments.
        o when a preset is loaded with less channels than the one it replaces and signal is spplied, a low level 12kHz tone or DC offset may appear on the unused channels.
        o if a program is loaded from a card and an <update> is performed the program is saved o internal memory rather than back to the card.
        o if the sample rate converted is enabled, it will become disabled at next powerup
        New Modules (documentation in latest Vsig)
        o AUDIOMUX – audio multiplexer
        o COMPRESSOR2 – same as COMPRESSOR but smoother, uses more resources
        o DELAY_XF – Multi-Tap Crossfading Delay Line
        o EQS – Double Precision Series Equalizer
        o H3000OSC – H3000-type Modulation Oscillator
        o MODDETUN – Audio Signal Detuner with Modulation
        o OVERLOAD – Audio Signal Overload Detector
        o C_LOG – logarithm to any base
        o C_POWER – exponent generator
        o SMONITOR – combined monitor and text monitor
        new double precision EQ presets
        12 40 DP_St.EQ45
        12 41 DP_St.EQ65
        12 42 DP Stereo8 Grafic Eq
      • #117557
        Thanks a lot Eventide!
        I'm very very happy to see this news!!
        I need to find my slow CF card to do the update as nowadays fast cards seems to not work, and then I will do the "drive test" and post here the result.
        prot
      • #117581
        Hello Eventide,
        – Update to V5.22 from CF works fine (I have had to find slow 32MB card to make it work)
        – SRC setting is kept after power off/on – Thanks!
        – PREV PROG – is much better but still with problems:
        Maybe it?s just my H7600 but, I still encounter this phenomena of module switching to PROGRAM 10 ("H7600 Banks") or 11 ("Mute"). This happens now much more often than it used to in previous software version if MIDI NOTE ON command is used from remote pedal board. After every 3 or 4 selecting of PREV PROG the module switches to PROG 10.
        It happens less frequently with NEXT PROG. If I use analog switch connected to SW1 and SW2 and set control of PREV PROG/NEXT PROG to TIP1 and TIP2 – it works much better but not 100% good. The problem is then seen quite rarely (~once per 100 pressing of analog switch)
        So to sum up its better, and big thanks to Eventide for the new software load, but I'm still looking forward your support regarding this unit switching to program 10 or 11. I hope that it?s maybe just something with my module setting and not bug. Anyway there was already post on this forum describing the same issue.
        thanks for still taking care about H7600 !!
        Its beautiful machine and deserves care 🙂
        prot
