H8000
Home Forums Products Rackmount H8000
    • #108057
      ulfiyya
      Hi there,
      Is is possible to write one preset with Harmonic enhance, eg and reverb to one DSP and
      Another effect chaine like pitch , flange…to the other DSP?
      Thanks
    • #122533
      Yes. The H8000 series have two DSPs. Except for very large (monolithic) presets which can require both DSPs, you usually run one program on each DSP. Depending on how the routing is set, these can be in series or parallel.
