H8000 analog & aes 8 track
Home › Forums › Products › Rackmount › H8000 analog & aes 8 track
    • #112637
      Hi
      I am using Analog & aes 8 track for my H8000fw routing witch is working fine with no problems from the aes 1 -4 and anaolg ins and outs 1 and 2 (dsp B is analog and A being Aes).
      Only problem is i am not getting any output from analog outputs 3 -4 although there is an input reading?
      Any help would be much appreciated
      Thanks
    • #139404
        Hi Tim
        What outputs are you expecting from analog 3 and 4 that you are not getting ? Have you set the meters to show outputs ? What do you mean by "there is an input reading" ?
      • #139407
        Hi Nick
        I have sorted the problem i over looked certain presets that i was using that where making some of the outputs dead.
        Thank you for your replie
        Tim
