H8000 Analog Outputs
Home Forums Products Rackmount H8000 Analog Outputs
    • #106612
      TidesN
      I have the analog AllB selected and have preset 5415 selected and my output is ch 1 and ch 6.  Since my analog only outputs ch 1-4 I am not able to hear both outputs.
      I tried another preset 12 which is a pass through (no change to the signal) and it also outputs ch 1 and ch 6.  Something is messed up I think.  What is wrong here?
      Thanks for helping.
    • #119411
      IDeangelis
      This description is not helpful, unfortunately.
      -what do you mean by "my output is ch 1 and ch 6" ?
      -how the unit is connected? Please specify which I/Os are used.
      The only thing I understand is that you are trying to use a 5.1 preset (#5415) with analog outputs…and that can't be done as you'd need 6 channels, whereas the unit provides a max of 4 analog outputs.
      To use the 5.1 presets you eed to load the correct routing and use digital connections like ADAT or DB-25 Aes Ebu.
      best
      I
