October 8, 2008 at 3:19 pm #105866CharlieRedsealMember
Hi
have read a bit that the convertors in the h8000 are superior to quite a few others.
i am running Motu192HD with Apogee Big ben maser clock, into SSL X Rack.
would i get a better sound if i used the H8000 convertors as my main ones?
Is this possible ?
many thanks
Charlie
October 8, 2008 at 3:23 pm #117918IDeangelisMember
Hi Charlie
yes…the converters are quite good!
you'll have to judge w/your ears (that's the fun part of it, right?).
You can connect analog sources to the analog inputs of the unit…or you can feed the H8000 digital signals and convert them to analog via its analog outputs. All is possible…provided you use or create the proper I/O routing of this powerful unit.
all the best
I
October 8, 2008 at 3:27 pm #117920CharlieRedsealMember
Cheers I
Will give it a go now
best
Charlie
October 8, 2008 at 4:43 pm #129089Sonic NomadParticipant
You will enjoy it. I now always record into Pro Tools LE and Logic 8 via the H8000's A/D as it sound rather better and "wider" than those on my Digi003.
Just last week Isetup the H8000FW as the primary sound card with Logic using the H8000 for both ins and outs. was a bit of a complex setup but works very well. It allows me to use all the analog in and outs into logic and also use two channels effects on on both DSP A & B running in series. That is of course if Im not running monolithic presets.
October 8, 2008 at 7:55 pm #129090CharlieRedsealMember
Hi D
thanks for the info , am using logic as well.
if its not a hassle, could you tell me how exactly you got your h8000 set up to run as main convertors,
especially the h8000 routing,ins and outs ectMany thanks
Charlie -
October 9, 2008 at 1:22 pm #129092IDeangelisMember
Try exploring the factory Routings area. There you start loading one and check if it works for you. You can also create and store your routings here.
To access ROUTINGS store/recall area press & hold the PROGRAM key for a few seconds.
Routing #10 ANALOG A-B is a good starting point.best
I -
October 11, 2008 at 1:59 pm #129100Sonic NomadParticipant
What DAW are you using?
October 13, 2008 at 11:00 am #129102CharlieRedsealMember
Am using Motu 192 HD with Mac G5 and Logic 8 Pro
cheers
Charlie
