H8000 FW QUESTIONS
Home Forums Products Rackmount H8000 FW QUESTIONS
    • #106198
      lionelred
      Hi There
      I have been seriously considering buying one of these.
      I own an eclipse which I like very much but am starting to find it limiting.
      Can i use this like a audio interface(sound card)? and does it have sampling capabilities (174secs) or is that related to delay?
    • #118549
      IDeangelis
       Hi
      the H8000FW can be used as an audio interface. Different kinds of limitations may exist, depending on the used DAW software.
      The unit has 174 seconds for mono sampling time @48KHz sampling rate, in addition to many other seconds for delay. The sampling memory can also be used as delay memory, depending on which module is used in a preset. Most delay presets though do not use sampling memory.
      best
      I
