- This topic has 4 replies, 3 voices, and was last updated 2 years, 4 months ago by
tonyshred.
September 9, 2023 at 7:56 am #174106
Hi everyone
Is there any way to create custom monolithic patch from two programs A/B?
I haven’t found how to save both program in one.
Thanks,
Mik
September 9, 2023 at 9:17 am #174107
It happens by itself when the patch is big enough and requires to go monolithic. It’s nothing that you can choose up front.
September 9, 2023 at 10:16 am #174108
ok I got it, but how to save both A/B in one preset? to recall both at same time
Sorry I just got the unit and haven’t found it in manual.
is there something like global scene?
November 15, 2023 at 5:46 pm #175771
I’d like to know how to do this as well. Basically how to send an e.g. Long Delay preset in A > Reverb preset in B, or combine those into one preset.
Any help is much appreciated.
November 16, 2023 at 3:03 am #175804
I’d like to know how to do this as well. Basically how to send an e.g. Long Delay preset in A > Reverb preset in B, or combine those into one preset. Any help is much appreciated.
You can use vsig to combine several algorithms into one algorithm, if it gets too big it will go into monolithic by itself. But there are many muliteffect algorithms already in the box so without knowing what you try to achieve it’s probably there already. But if you want to load algorithms in both DSP’s simultaneously I think you need to do that via MIDI.
I am pretty sure those are in the box already.
