- This topic has 6 replies, 2 voices, and was last updated 2 years, 7 months ago by
Fender17.
December 6, 2023 at 2:42 pm #176572
Is it OK to place H8000 into 2U rackcase? One of those plastic ones. It would have open front and back (when in use) and there is less than 3/4 of inch of space below and above the unit (in rackcase)….. And about an inch on both sides.
I am going to run it indoors, not on sun and so….
It would be more convenient to have it in 2U case, than in 3U with one empty position. But I do not want to fry it…..
December 6, 2023 at 5:02 pm #176577
Since it is an older machine that is known to run hot, I would recommend playing it safe and putting it in a case with extra room.
December 7, 2023 at 2:25 pm #176598
OK, I sort of expected that answer. So, 3U rackcase……:-(
And Eclipse? Does it need extra space, or 1U is OK? (I fear the answer.)
December 8, 2023 at 8:18 am #176607
I’ll quote the Eclipse user manual just for fun “Keep the Eclipse well ventilated, dust-free, dry, and, like Little Bear’s porridge, neither too hot nor too cold.”
Personally, I give all of my vintage rack mount gear space in the racks if possible. These machines can be expensive and difficult to service, so my suggestion is to play it safe.
You could do a test with either machine in the smaller cases and see how much heat is being generated and make a decision based off that.
December 8, 2023 at 11:51 am #176616
OK, good suggestion. I will try 3U case for Eclipse and two other 1U devices (they are only about 3″ deep, so there will be space below and above Eclipse at the rest of area) and I will see, if it gets too hot.
You are right that H8000 is becoming pretty expensive, so I’ll place it in 3U case…
December 8, 2023 at 12:02 pm #176617
Sure thing, I did just run both the Eclipse and H8000 for a few hours and the H8000 is noticeably warm while the Eclipse doesn’t seem to put off much heat, so you should be fine. I would still recommend doing the test to make sure the amount of heat is ok once it’s in a case, mine is in a rack with nothing surrounding it.
December 8, 2023 at 12:55 pm #176619
Thanks a lot.
