Home › Forums › Products › Rackmount › H8000 Midi CC to control global wet/dry mix
I have searched and searched and read that you can control the global wet dry mix of DSP A and DSP B. However, I can not find any documentation on what CC# you use to control it.
Does anyone know?
Thanks
Use the "Press and hold SELECT" scheme to bring up a modulator. Then, assign whatever CC you want.
See "REMOTE CONTROLLING PARAMETERS" on UM p.111
Thank you!
