I’ve got an H8000 I haven’t used before. I did a factory reset, set the routing to analog A->B, hooked up the XLR connectors labeled analog, set the program to “Thru” and… nothing. Here’s what I’ve debugged so far:
- The lines I have running to the input do in fact have signal on them – demonstrated by hooking them up to powered speakers.
- Metering shows nothing when set to input
- If I run the 440 Oscillator program, I do get 440hz on the analog outputs and I can see it on the meter when I set metering to output
- All input and output levels are set to 0dB gain
- A manual look at the routing shows analog 1/2 to DSP A, DSP A to DSP B, and DSP B to analog outputs like you would expect having loaded the Analog A->B routing
- A very hot input still does nothing
What am I missing? Is this a damaged unit?
