Hi everyone
I'm using the older H8000 model (Not A nor FW versions)
Is it possible to use the AES ins and outs AND get the 2 analogue outputs to mirror the digi outputs?
If this is possible it would be great to monitor the analogue outs during mixing, as once I up the buffer in PT10 for the mix process when I monitor the digi outputs obviously the latency makes monitoring the signals impossible.
Further questions and problems:
Would upgrading to FW eliminate this?
Also – when I use the unit in analogue io mode, the units seems to function ok for an hour or so, then seems to give up with distorted sounding output at first leading to nothing (as if the unit has crashed)
Anybody else had this problem?!?
Thanks guys and girls…
