h8000 spdif
Home Forums Products Rackmount h8000 spdif
Viewing 9 reply threads
    • #113965
      sectiond
      Hi ,
      I would like to set properly my h8000 in spdif mode for use with my motu 828mk3
      and the setup looks very compliquated ( so many pages & parameters to dive in !!! ).
      and i don’t know which one to set to spdif.
      i don’t use the 8 channels.
      Any help would be apprecied,thanks !!
      Bruno.
    • #145517
      This is a sophisiticated unit, and a little User Manual study is usually necessary to use it.
      That said, if you were to load the "SPDIF A->B" routing, that might do it for you (I'm assuming you have an H8000 and not an A or FW). Look at:
      1) LOADING ROUTING CONFIGURATIONS on p.19
      2) "SP DIF A->B" on p.20
    • #145660
      sectiond
      Right,i remember seeing that in the manual..will try this ,thanks!
    • #145692
      sectiond
      hi, i tryed the spdif A>B setting but it doesn’t work!
      i have the “EXT” led blinking under 44,1khz on the left of the h8000..
      and in logic i see only the output 11/12 spdif of the interface available and for  the input only 11/12 but not spdif.
      • #146730
        sectiond wrote:
        hi, i tryed the spdif A>B setting but it doesn't work!
        In what way does it not work ?
        If you go to SETUP what do you see beside "Source" ?
        If you hit [clock]  what do you see ?
        sectiond wrote:
        i have the "EXT" led blinking under 44,1khz on the left of the h8000..
        This means that a routed input is unlocked – it may be one you are not using. The answers to the questions above will tell us if the SPDIF is the problem.
        Don't understand this – I don't know Logic well.
    • #145699
      Things to check:
      1) Cabling
      2) To select the S/P DIF digital input, set DIN 1/2 on the inputs menu page in the SETUP area to S/P DIF.
      3) To set the system sampling rate to the external clock’s rate, set the Source parameter on the clock menu page in the SETUP area to S/P DIF 1/2
    • #145830
      sectiond
      will try again ,thank you 🙂
    • #145883
      M-Goldie
      I use an 828mk3 with my 8000FW & 7600 – if I were you I would consider using the analog ins & outs of the 8000, that way you will be getting the 2 x stereo effects processors for use as two send/returns from your DAW.   SPDIF will only give you one stereo send/return.  Has your 8000 got adat?
    • #146727
      sectiond
      i have only one pair of ins & outs on my h8000..but i would like to use it in spdif to free some analog ins & outs on the motu for other devices and for the better audio quality
      by the way..is that true that you get better quality in spdif than analog ?
    • #146728
      sectiond
      yes,my h8000 has ADAT
    • #146731
      sectiond
      Problem solved !!!
      i had some wrong settings in the input & output pages and in logic i/o plugin (audio interface in & out routing).
      before the 828 i had an ultralite and the spdif was 11/12.. now it is input 15/16 and output 13/14..
      happy that it works finally.. thank you all for the help 🙂
      best,
      Bruno.
