H8000 Startup Error
Home Forums Products Rackmount H8000 Startup Error
    • #110912
      M.ANGELO
      hi, when i run my h8000 v.5.5 software i see a startup error message:
      "config jumpers LN102,103 invalid Check U106"
      This problem is born when i ve tried to pass from Analog to ADAT ROUTING mode.
      Now , the WHEEL doesn't run…
      I ve cleared INTERNAL and SETUP, but get the same message.
      Can i re-install V 5.5 software?is it a good idea?
      Can you help me? thank you!
    • #124456
      The message suggests that it is a hardware problem associated with U106, which is a large socketed chip to the center front of the motherboard.If you are handy, you could try "wiggling" this in its socket, otherwise it probably needs service.
      If this started immediately after a software update, you could try repeating the update.
    • #124457
      M.ANGELO
      Done!
      now, u106 works good!
      thank you!!!
