H8000 White screen
Home Forums Products Rackmount H8000 White screen
    • #112210
      hombregorilla
        Hi there,
        My H8000 is like frozen on a white screen. It happened when i change the clock reference.
        Now i cannot do anything but switching the unit on/off. Nothing else respond.
        Does anyone has met this problem ?
        Is there a reset process on start up ?
        Thank you.
      • #127273
          See "Start-Up Options" in the User Manual.
          Try "Clear the internal setup" (SETUP key) first. If that does not do it, try "Clear internal programs and setup" (8 key).
          One of these should fix it. If you have H8000 or H8000A, make sure that WordClock is disabled, unless you always have a valid WC connected (see UM).
