H8000 with hdspe
Home › Forums › Products › Rackmount › H8000 with hdspe
    • #111638
      Just need some advice my audio card does not support Firewire so I'm using ADAT it does support AES/EBU should  I go this route? or just get a card with FireWire, My mixer supports Firewire and ADAT but not AES/EBU
      Thanks
    • #125977
        Probably depends on how many channels and what sample rates you need. ADAT and AES are fine, but the first is best at 48K, the latter will need many cables. A FireWire card is cheap, and will pass 16 channels both ways at 96K on a single cable.
      • #125980
        Suggestion on a Firewire Card?  I use sonarx3p  I was just looking to go to a Rme Multiface II  or is this just over killing it pretty much what I have now just with FireWire… 24/48k I use most of the time mixer is 16 channles but in sonar I go to 60 something channels some times..  Cables is one thing I have tons of and a few snakes.
