H8000A vs H8000FW
Home Forums Products Rackmount H8000A vs H8000FW
Viewing 3 reply threads
    • #115336
      devonbrent
        If an H8000 has the Options card installed with FireWire/ADAT/WC/etc does that make it a H8000FW then? Am I missing anything?
        Devon
      • #151985
          If you have the FireWire card and the appropriate software, you have an H8000FW.
          • #151986
            devonbrent
              Is having the appropriate software simply updating the software that’s on the firmware page by Compact Flash card? I only see the 5.6.1 software on the download page.
              Devon
            • #157012
              selimozturk66
                Do they have the same presets adat ins outs ?
            • #151987
                The 5.6.1 software will be fine. You need a Compact Flash card to update an H8000FW.
                If the software on your unit is very old, you may need to update it twice, once before, and once after, installing the FW card.
              • #157013
                selimozturk66
                  Do they have the same presets installed?
                  Do they both have ADAT in’s and out’s?
                • #157044
                    Do they both have ADAT in's and out's?
                    If they run the same software version they will have the same presets.
                    They both have ADAT.
