H8000FW Address Error – Help Needed
Home Forums Products Rackmount H8000FW Address Error – Help Needed
    • #116496
      Hi all,
      One of our H8000FW is displaying an address error. Any help would be greatly appreciated.
      “An address error has occurred. (E12)”
      Program: 0640E2
      Data: 00785
      Please write these down and reboot.
      Thank you.
      Glenn
    • #157852
        I'm afraid that this is a "catch-all" error that can have many causes. It is most likely to be some kind of hardware problem.
        If it happens often, at different times, showing different numbers you should contact support@eventide.com
        If it happens only when doing one particular thing and showing the same numbers, you should give us more information.
        If it happens at startup, you should remove any cards from the slot and re-initialize (see UM).
