H8000FW AES connection (multi channel)
Home Forums Products Rackmount H8000FW AES connection (multi channel)
    • #105894
      I know that the H8000FW has a stereo AES protocol (up to 96khz) and a multi channel I/O option for 8 I/O's I believed (please correct me if i'm wrong) several question about his AES (8 I/O) option: 1. Is it posible te send/return 8 channels at 96 khz at the same time?
      2. If my audio Interface doesn't support this 8 I/O AES protocol, what options do I have if I would like to connect it by AES 8 I/O?
    • #117967
       The H8000FW offers 4 channels AES-EBU via XLRs connectors + 8 channels via DB-25 connector and an optional cable for it. If your audio interface doesn't support (multi-channel) AES-EBU, there is no way around. You can only buy  professional one that supports 8 channels. Obviously the configuration of sending/returning 8 channels at 96KHz depends on such hardware and the DAW used with it. The H8000FW can operate via 8 AES-EBU I/O at 96 K.
      best
      I
    • #117969
      Thanx again Italo for you quick reply!
      Well, thats just what I ment; I only would like to use the AES 8 I/O by the DB 25-connector (and cable). For streaming 8 channels of FX at 96khz.
      Well, I've got a Lynx AES16 PCI card what could do the job. The Sad part is that I would have to intergrate the AES16 PCI card as another ASIO in my DAW/ PC (for make a connection with my H8000FW as I/O's interface). And since my computer (PC XP proff. sp2 32 bits) supported one ASIO, that's gonna be a big prob.
      My main ASIO audio-interface is my Prism Sound Orpheus.
      Also it's a bit nasty working and switching with several software mixers (since the orpheus and Lynx AES comes both with a software mixer/interface).
      So I guess, this option is gonna fail.
