- This topic has 3 replies, 2 voices, and was last updated 1 year, 11 months ago by
Thorsten42.
April 5, 2024 at 4:39 pm #180663
I was re-arranging my studio cables (gear stayed put) and run some tests afterwards.
The H8000fw when switched to routing option „10 Analog A->B“ shows the meter for all 4 analog inputs with max level as well as for all 8 analog outputs.
I thought that something was wrong with patchbay and unplugged all connectors on the unit directly but the levels stayed the same with nothing connected.
When I switch the routing to „12 Adat A->B“ the unit works fine (this is the main operation mode for me),
As soon as I select a routing option which includes the analog in/outs again max. level showing on the meter.
I switched the unit of multiple times but no change.
I also removed the top cover but nothing out of the ordinary here as well all ribbon cables are well seated.
Any ideas what could be the reason for this behavior?
April 5, 2024 at 4:46 pm #180666
There are a variety of input gain parameters on the H8000. Have you look at the Levels menu and made sure everything is at 0?
April 5, 2024 at 5:06 pm #180667
@tbskoglund, yep I checked the gain and all „0“ when I reduce the gain the meter level goes down as well.
it is odd that it shows 8 analog outputs on the meter since the unit has only XLR connectors for four analog outs to my understanding?!
April 7, 2024 at 8:42 am #180713
Quick question what does U500 do on the main PCB?
When I ran a couple of additional tests using the routing utility software I discovered that also the 4 AES/EBU channels encounter the same problem.
When using an audio generator patch I could hear it in the background through all the noise on the outputs.
it sounded similar if you use a digital protocol without proper Sync (even in this case we used analog outs with stable/locked in wordclock).
I took another look at the main board since „both“ analog/digital boards in this area are failing it had to be something they share.
The only single socketed IC in this area of the board was U500 so I took it out and re-seated it and guess what – All is well again no issues with the 4 ins/outs analog/digital no nasty noise just pure enjoyment:)
As the distorted signal reminded me of sync issues I wonder if U500 is (partly) responsible to generate the Clock/Sync for this part of the H8000FW?
