Hi there,
I've got an H8000fw (OS is quite old – a few years) connected via ADAT to a Sonic core XITE-1. No other connections besides 8 channels of ADAT I/O. The H8000fw is set up as FX sends from the XITE-1. Sample rate is 48000.
I get clicking and pops every few seconds under all reasonable combinations:
XITE-1 Master, H8000fw clocked to ADAT:
– The H8000fw clock page sometimes says ADAT is slipping but then it locks in at 48000.
– Sometimes the clocks says it's at 47999 or something like that.
XITE-1 Slave to H88000fw's ADAT, H8000fw set to internal clock 48000:
– Still get clicks and pops.
Sometimes, I don't get clicks and pops for a while, and sometimes they are there in abundance.
Today I hooked up a Meric Halo ULN-8 attached via AES/EBU to the XITE-1, and slaved to it no problem. No clicks and pops here.
I also have a Symbolic Sound Pacarana which is slaved to the XITE-1 and it is okay too.
So I'm just getting the clicks/pops with the H8000fw right now.
As an aside: When the H8000fw boots I get a startup error that an sram checksum has an issue.
What should I try?
Cheers
