H8000FW “EXT” light blinking
Home Forums Products Rackmount H8000FW “EXT” light blinking
    • #105967
      lightsong
        I want to route the signal from a Line 6 Vetta HD via the FX loop to/from the H8000 using the digital I/Os. I've followed all the instructions in both the Vetta and the H8000 manuals but there is no apparent signal going to the H8000 and the EXT LED continues to blink. Can you help?
        Thanks,
        John
      • #118111
         Hi John
        the H8000 has a powerful architecture, providing ROUTINGS options for all sort of I/O connections and configurations. You don't mention which digital connection you want to use…but I may assume your amp has a simple S/Pdif output connector. I'm not sure if the Vetta FX loop has a digital I/O though. So….
        more info , please!
        thanks
        I
