H8000FW – Factory Only testing duration
Home Forums Products Rackmount H8000FW – Factory Only testing duration
Viewing 3 reply threads
    • #116476
      VicWind
        Hi – I’ve been trying to resurrect this 8000 and keep getting the “Faulty Preset installed – Contact Factory” message.
        Steps I’ve tried so far:
        1. re-seated the U106 and U205 chips and cleaned things up a bit on the pads.
        2. Tried to clear all using the 8 key on startup.
        3. Tried sending “Mute” by holding Program on startup.
        4. Tried installing 5.61 on a new Sandisk CF with a Sandisk PCMCIA sled. This was encouraging, as it got to 100% installed, then said Failed.
        5. Re-started and am going through the Factory tests. Last I checked (and it’s been over 2 hours now), it was at T=1125 (not sure if that’s a test count number?).
        I’m hoping that it’s reading and re-writing over all the memory blocks and that I’ll then be able to install this OS update so I can clear that error message about the Presets being newer than the OS.
        My question is: how long are these tests supposed to take normally?
        Thanks very much for any help anyone can enlighten me with. I gotta get this guy working again!!
        CHeers
      • #157769
          The tests run continuously until you stop them. T= gives the number of tests performed. If E= is greater then 0, that is a failure.
          Don't run any flash or CF card tests more than a few hundred times, as these parts can only accept a finite number of write cycles.
          Does sound like you may have a flash memory fault.
        • #157770
          VicWind
            Thanks, Nickrose!
            I let it run for the last 12 hours so I will stop the test.
            Can an NOS flash memory be purchased still?
            Cheers
          • #157786
            VicWind
              Thanks again, Nick. I’ve received an RA from Jerome, and am sending the unit in for repair. Glad it’s an option, given the rarity of those chips!
              Cheers
            • #157779
                With difficulty. They're pretty obsolete.
