H8000FW Motherboard info after battery replacement
Home Forums Products Rackmount H8000FW Motherboard info after battery replacement
Viewing 3 reply threads
    • #114687
      dalegoodridge
        I have just changed the internal battery on my H8000FW and have noticed that the time and date in ‘Motherboard Info’ in ‘Information’ has gone strange. Also the same with the hours used.
        Does anyone know if you can set the time/date or if it is possible to return the hours used to normal?
        Everything else is working fine.
      • #148892
          The time and date and power hours are not actually used for anything, which is why there is not a UI to set them.
          You could try running the RTC (real time clock) test. Hold down '1' at powerup,  release when asked. Turn wheel until  "(201) RTC test". Hit SELECT. When it shows P=1, hit SELECT to stop.
          This may or may not help, but these numbers don't matter.
        • #148901
          dalegoodridge
            Thank you Nick. 🙂
            The RTC test reset the date to 01/01/1970 and reset the hours total.
            I know it doesn’t matter but at least the OCD in me is now satisfied!
          • #174935
            RossJoyD
              bello, need change battery to my h8000fw…..wich kind of battery?
              the in Advance
              • #174956
                  3V Lithium BR2330 (Panasonic number) or CR2330
