I have an H8000FW. I have connected the four analog inputs directly to the outputs of my instruments. The H8000FW is connected to my RME UFX II using ADAT I/O and AES.
I want to configure the AES output to send the dry signal from the analog inputs of the H8000FW, while sending the processed (wet) signal through the H8000FW to channels 1–4 of ADAT. However, I’m getting confused with the routing.
Could anyone provide some advice?
Thank you
