H8000FW Routing Question
Home Forums Products Rackmount H8000FW Routing Question
Viewing 4 reply threads
    • #114540
      MFPhouse
      hi Folks,
      My H8000FW is connected to a RME800 via ADAT.
      I want at the H8000 following Routing
      ADAT Input 1-2 goes to DSPA  and out ADAT 1-2
      ADAT Input 3-4 goes direkt to AES 1-2 out and this Signal came back to Input AES1-2 and out to ADAT3-4
      ADAT Input 5-6 goes to DSPB and back out to ADAT 5-6
      ADAT Input 7-8 goes direkt to AES 3-4 out and this Signal came back to Input AES 3-4 and out to ADAT 7-8
      all, at 44,1
      M problem is i didn´t get the AES Input back. What do i wrong ?
      It is possible ?
      Thank you
      Michael
    • #148070
      This ought to be possible.
      Check your sync sources and make sure that all inputs show as locked.
    • #148073
      MFPhouse
      I still stay on sys 5.5  , did i need 5.6 ?
      • #148075
        Shouldn't make a difference.
    • #148081
      MFPhouse
      …sorry , i can not get it.
      I have Problems to fed the Inputs of the AES 1-2 and 3-4 . The Rest works fine.
      I need this Signals directly routed out to ADAT 3-4 and 7-8. Can you give me please a Step by Step Instruction .
      Maybe ( if necessery) to change in this Routing Scenario the AES to 5-6 and 7-8 ?
      Backround : I just want to plug Two other Stereo Hardware Units thru the H8000 via AES I/O 1-2 and 3-4.
      Thank you
    • #148082
      Please "Check your sync sources and make sure that all inputs show as locked." as suggested earlier.
      I would suggest that you try the H8000 Routing Utility, as found on the H8000FW  Docs & Downloads  page.
