H8000FW: Sampler don´t play reverse audio
Home Forums Products Rackmount H8000FW: Sampler don´t play reverse audio
Viewing 5 reply threads
    • #108764
      strong1096
      my H8000FW has a slight problem playing reverse audio. I´d like to point out an issue with presets 5212 & 5216 on OS 5.5 & 5.6B1:
      1st: record signal, counter runs fine
      2nd: press stop, counter resets to 0.000
      3rd: press play – no signal (5.5) / alternating (high) sinus frequency  (5.6B1)
      Downgrade to OS 5.3 works correctly but reduced functionality vs. OS 5.5 (no TF/MF presets etc.).
      Any advice how to fix that issue?
      F
      PS: the other sampler presets play audio flawlesly in forward direction (all OS 5.x)
    • #123449
      Sorry – a new one to me. I'll look into it.
    • #123646
      strong1096
      Hi Nick,
      did you meanwhile found a solution? Thanks for your efforts in advance. BR, Flo
    • #134688
      No news yet. Sorry. In the meantime, suggest that you don't use these presets.
    • #135806
      strong1096
      Hi Nick,
      following up to the issue i´d like to know if there is a chance to get my 8000 up to date. The unit + new OS release 5.6 does not change its behaviour of reverse sampling. Not working in sampler reverse presets (defunct, state <> ready, no record possible). Please suggest a proposal how i can move forward. Thanks, Flo
    • #135812
      Hi Flo
      Sorry for lack of progress on these. On looking at them aon V5.6, 5212 indeed produces no output. 5216 seems to play back OK, but the <stop> key does not work.
      So, for now I would suggest you work with 5216. I'll add them to the list for the next release.
