H8000fw won’t boot up
Home › Forums › Products › Rackmount › H8000fw won’t boot up
    • #107253
      Hello ,
      i am having an issue with my H8000FW: once i turn it on, it gets through the Logo, onto the "powering on…1.292" screen, then the whole LCD switches off, leaving only the input LEDs all lit up.
      nothing is connected to it, and i tried restarting it several times.
      Any suggestions?
      thanks in advance,
      A.
    • #120731
        Three things to try (in order):
        1) Return the unit to factory defaults as described in the UM. If this doesn't help..
        2) If you are handy, disconnect the power, remove the top, and reseat all socketed chips, especially U106 (square chip near center on motherboard). If this doesn't help..
        3) support@eventide.com
