Home › Forums › Products › Stompboxes › H9 5.8.5 software update problem
January 17, 2020 at 8:08 pm #115705
mickglossop
ParticipantWhen I select “Install software” in the H9 Control app, I get the message:
“Downloading update failed.
Could not reach Eventide server. Please check your network connection”
This is strange becasue just 5 minutes ago I successfully updated to 5.8.2
January 17, 2020 at 9:08 pm #153769
We have a power problem at Eventide (started a few hours ago), so many things are down.
It may take a few days to fix (but hopefully not).
January 24, 2020 at 5:12 pm #153871
mickglossop
ParticipantHi – this still seems to be a problem.
Any news?
January 31, 2020 at 7:26 pm #153972
paujosa
ParticipantThe same problem just now. “Downloading update failed. Could not reach Eventide server. Please check your network connection”
PC windows 8
February 1, 2020 at 8:01 am #153973
mickglossop
ParticipantI’ve discovered that if I use Mac OSX 10.10 the update works fine.
Previously, I was using Mac OSX 10.8.5Thanks for your help. -
February 1, 2020 at 1:34 pm #153974
paujosa
ParticipantFinally I have updated to 5.8.5 with the iphone without any problem.
Finally I have updated to 5.8.5 with the iphone without any problem. -
February 7, 2021 at 11:19 pm #157102
aurelman
Participantbonjour j’ai un gros probleme, j’ai le meme message d’erreure! Could not reach Eventide server. Please check your network connection”
je ne peut donc pas utilisé mes 3 pedales h9!
c’est urgent …
February 20, 2021 at 10:37 pm #157226
genesound
MemberI was able to update one of my H9s, but when I went to do the other one I got the unable to reach server message. I’ve rebooted everything and the issue persists. My internet connection is fine.
February 20, 2021 at 10:42 pm #157227
We are aware of this issue and it may be weather related. Please hang tight. Unfortunately, this may take until Monday to resolve.
Any news?
What device do you use for H9 Control? Could you try it again and take a screenshot? Can you try that on a different device, like a desktop via USB? I just tried updating my H9 to 5.8.5 and it worked fine.
February 10, 2021 at 2:30 am #157126aurelman wrote:
bonjour j'ai un gros probleme, j'ai le meme message d'erreure! Could not reach Eventide server. Please check your network connection"
c'est urgent …
Sorry – it sounds as if you have a local network problem which is beyond our control. I would suggest that you try a different computer.
Désolé – il semble que vous avez un problème de réseau local qui est hors de notre contrôle. Je vous suggère d’essayer un autre ordinateur.
February 21, 2021 at 11:56 pm #157233genesound wrote:
I was able to update one of my H9s, but when I went to do the other one I got the unable to reach server message. I've rebooted everything and the issue persists. My internet connection is fine.
This should be fixed now.
