Home › Forums › Products › Stompboxes › H9 and BOSS ES-8 MIDI Control
October 15, 2015 at 1:14 pm #112940njstoehrMember
I am a complete noob when it comes to MIDI control. I have seen a number of videos online showing the H9 controlled by various midi footswitches to include the BOSS ES-8. I have tried, very unsuccessfully I might add, to select H9 presets with my ES-8 and could use a little 101 type help in getting this setup.
I have connected the midi-out/thru on the ES-8 to the midi-in of the H9. I changed the H9 midi “RCV CH” to 1, “CLK IN” set to “ON”, and “OUTPUT” is set to “THRU”. On the ES-8 I have programmed a patch to send PC 11 out on Ch 1 in the hope of selecting the “What I’m Looking” preset. Unfortunately, when I select the patch on the ES-8 it does not change the preset on the H9. I am obviously doing something wrong and have no doubt that it is a simple fix but I am at a loss. Can anyone offer some insight?
Thanks.
October 15, 2015 at 3:42 pm #141056
I'm thinking you should re-initialize the H9 and leave it at default settings. If you still have no luck, this would probably be an issue for Boss, rather than us.
October 16, 2015 at 3:25 pm #141079njstoehrMembernickrose wrote:
I’m thinking you should re-initialize the H9 and leave it at default settings. If you still have no luck, this would probably be an issue for Boss, rather than us.
Thanks Nick. I have tried that. Reset both actually. Still not working as I would have hoped. Before I call BOSS perhaps someone can point me in the direction of some “MIDI for Dummies” reading materials. Lol
October 16, 2015 at 3:44 pm #141080
Essentially, if the H9 is at default settings, and you send it a low numbered (below 100) MIDI Program Change, it should load a preset without you doing anything else.
Which preset it loads is a different issue, but we can worry about that later.
If this is not happening (as is seems to not be), it's probably one of the following:
1) Bad cable
2) Cable not plugged into the right places
3) You think you are sending it a program change, but you are not.
4) Hardware fault on H9 (possible but unlikely in this case).
The first 2 are easy to check. The third (most likely) requires a conversation with Mr.Boss.
October 20, 2015 at 2:09 am #141176njstoehrMember
Finally got it figured out. Picked up a new midi cable, plugged it in and off to the races. Turns out the one I had was wired incorrectly, so I fixed it. Now I have to functioning cables and can switch presets with no problem. Thanks for the help.
January 23, 2017 at 2:55 pm #145556steve17Member
Hi njstoehr,
I too am new to the H9 and midi control. I came across this post and I was just wondering if, a year later, you are still happy with using your ES-8 as a midi controller for your H9. Please let me know as I’ve just purchased an H9 and am thinking of getting the ES-8 soon.
Cheers,
Steve
January 24, 2017 at 2:45 pm #145572njstoehrMembersteve17 wrote:
Hi njstoehr,
Cheers,
Steve
I am very happy with the ES-8 and H9 control. I was new to midi at the time so it was a learning curve for sure. ES-8 is actually pretty easy to use with regard to midi, just take some time to look up as much as you can on line, especially youtube videos.
Good luck. I don’t think you will be disapointed in anyway. Again, just do some research, take your time, and don’t get too frustrated. It really is easier than it seems.
Nate
January 12, 2018 at 6:12 pm #148090Glen CrucianiMembernjstoehr wrote:steve17 wrote:
Hi njstoehr,
Cheers,
Steve
Nate
Nate,
I had a similar issue when I initially tried to get my ES-8 to control a Strymon Big Sky, H9 Max, and an H9 Core. No bad midi cables here, but I wound up making the ES-8 midi channel 1, the Strymon Channel 2, and the H9’s were 3 and 4. Also a noob, and really trying to trial and error my way through things. A few items I’d like help with.
Is it possible to choose a Memory patch on the ES-8, and have it pull up the correct sound on either a Strymon, or H9, but have them toggled to off or bypass? Basically this allows me to have all of the sounds at my disposal for a particular song live, but allows me to activate the sound from the Active switch for example on the H9. Thanks
January 25, 2017 at 1:50 am #145579steve17Member
Happy to hear that and thanks for the reply!
